Re: M hydraulics?
Posted by RustyFarmall on May 22, 2007 at 04:59:49 from (66.43.253.62):
In Reply to: M hydraulics? posted by M.Rad. on May 22, 2007 at 04:48:56:
The fitting on the right side of your M, and the forward fitting on the left side are common to each other, you can use either one to lift your drill. The left rear fitting is a "delay" connection, although if you are using just one fitting, the left rear would probably function just as well. Most of us use the fitting on the right side.
