Farmall Tractors Discussion Board |
Re: out of fluid
Posted by The Red on June 18, 1999 at 14:57:03 from (216.192.172.81):
In Reply to: out of fluid posted by Levy on June 18, 1999 at 12:04:34:
Levy, are you talking about the liftall pump? If you are the filler cap is next to the flat belt pulley assembly under the gas tank. Use NON-DETERGENT SAE 30 or hydraulic fluid to fill. The resivoir itself holds 6 quarts. You might need more than that.
Post a Followup
