Re: Re: Re: Farmall 100 (?) Serial Number Question
Posted by Stan(VA). on June 23, 2004 at 05:20:03 from (208.59.157.190):
In Reply to: Re: Re: Farmall 100 (?) Serial Number Question posted by Ramon on June 22, 2004 at 19:24:16:
The 357657 is a part number but it is for the touch control (hydraulics) housing. The engine block part number will be sort of hidden just behind the oil filter canister just to the left of where you saw the words "Firing Order". The engine's serial number is not cast like the other markings you've found but is stamped into a small flat machined surface just below #1 spark plug. The 11-30-Z is a date code for late November of '54.
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Farmall 100 (?) Serial Number Question
