Farmall Tractors Discussion Board
Farmall C Surging Battery Discharge
Posted by Tony March on November 13, 1999 at 18:02:27 from (146.186.225.101):
I've replaced the surge control spring and adjusted the carbeurator linkage but engine surges when going downhill, it's ok on level and going uphill or when under a load. What is the problem?
I've converted to 12 volt, replaced the generator with a 1-wire GM alternator and 12 volt coil. The alternator charges ok but when left overnight the battery discharges. I have seen sparks on the alternator when i touched the fan and alternator with a screw driver--engine not running. What can I do to keep battery from discharging?
Post a Followup
: Re: Farmall C Surging Battery Discharge
