Farmall Tractors Discussion Board
Re: Farmall C Surging Battery Discharge
Posted by Bob M on November 15, 1999 at 04:32:40 from (192.232.120.194):
In Reply to: Farmall C Surging Battery Discharge posted by Tony March on November 13, 1999 at 18:02:27:
Tony - Is the motor truly surging (RPM varying up and down) or is it just backfiring out of the exhaust? If it's the latter, it's pretty much normal with that tractor.
Battery running down with the motor shut off means either a bad alterator or a problem in the wiring. Try disconnecting the wire from the "BAT" terminal at the alternator - if the battery stays up overnite the problem is in the alternator. Also are you certain you have a true "one wire" Delco alternator?
Post a Followup
: Re: Re: Farmall C Surging Battery Discharge
