Farmall Tractors Discussion Board
Re: Ok...got the brake cover off and here is what I found -
Posted by Farmer Bob on November 17, 1999 at 19:47:55 from (207.227.187.183):
In Reply to: Ok...got the brake cover off and here is what I found - posted by Farmall Newbie on November 17, 1999 at 19:12:18:
First of all, with the scetchy info it's hard to say what you're working on. Assuming it's a tractor you have to find out where the oil is coming from ie; bad seal between brake and bull pinion or differential shaft...with oil on the brake lining you will have to replace them but not until you find the source of the oil/grease that's in the drum and on the lining. Post some other details like model and I'm sure the talent here can help you. FB
Post a Followup
: Re: Re: Ok...got the brake cover off and here is what I found -
