Re: Hydraulics on an A?
Posted by Haas on January 12, 2005 at 18:43:04 from (12.65.18.71):
In Reply to: Hydraulics on an A? posted by Bill57 on January 12, 2005 at 18:15:10:
Don't know if there was a kit to convert or not, but to do so would have required changing out the torque tube (bell housing) and the engine block. More likely what has happened is that some one took the front end of a Super A and attached it to the back end of and A. Or...someone had a Super A with bad seat supports and found some from and A, putting them on the Super A along with the serial tag. Lot's of things like this happen to these old tractors over the years. You can sort of check what you have by checking casting dates. All the major castings have date codes, so you can tell when they were manufactured.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
