Re: cuts out....gas?
Posted by El Toro on May 28, 2005 at 10:23:47 from (64.12.117.13):
In Reply to: Re: cuts out....gas? posted by ToddH on May 28, 2005 at 09:55:31:
That would be a good place to check the gas flow.
If ok, I would replace the condenser and then the coil if the new condenser doesn't help. Hal
Post a Followup
