Re: Farmall 140 4th gear trouble
Posted by CNKS on February 03, 2006 at 09:19:27 from (204.249.178.138):
In Reply to: Farmall 140 4th gear trouble posted by Hurst on February 03, 2006 at 07:31:50:
You either have worn shifter forks or the gears themselves are worn. Don't know about the 140, but the A/Super A has square cut gears that are inherently noisy. The forks can be built up -- I've never done it, but all you have to do to take a look is remove the cover, very easy.
