Re: Farmall A Carburetor
Posted by RustyFarmall on January 22, 2007 at 09:36:17 from (199.120.81.207):
In Reply to: Farmall A Carburetor posted by Brad in TX on January 22, 2007 at 09:11:47:
I will assume that you were thorough in cleaning the carb? The crud can hide really good sometimes. Is the float level correct? Maybe the two carb halves are warped, and you are not getting a good seal, thus allowing a vacuum leak? A vacuum leak can also result with a poor carb to manifold gasket, or manifold to head gaskets. What about the fuel inlet fitting? There should be a fine mesh screen in there also that gets plugged up sometimes. One more thought--have you tried running it with gas tank cap removed?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
