Re: B275 stops running
Posted by Hugh MacKay on December 29, 2007 at 03:11:31 from (216.208.58.166):
In Reply to: B275 stops running posted by Daniel Hindry on December 28, 2007 at 23:53:17:
Daniel: You speak of it running 15 to 20 minutes as long as there is enough time between those periods. How smooth does it run when it does run?
Sounds like the fuel system is sucking in air, while running. Then after it stops, if given time it will purge the air by graviety as the fuel tank is above the pump. If that is the case, the leak must be very close to the pump, even within the pump. The reason I say this, you don't mention having to bleed it to get it restarted. Quite often cracks in the fuel system can cause this, either lines, fittings, filter bases, even pump housing. I can tell you, some of these cracks can be hard to find, especially if it's small enough to suck air, yet not leak fuel.
One other thing could the return line from pump to fuel tank be plugged. I've never had this happen, thus I don't know the symptoms, but have noticed in discussion it causes problems. There are guys here on YT with this experience.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
