Re: Farmall H ignition
Posted by El Toro on January 09, 2008 at 13:08:36 from (64.12.116.73):
In Reply to: Farmall H ignition posted by dan harjes on January 09, 2008 at 12:45:51:
Your wire from your ignition switch should be going to the coil not from your alternator. With your points open you should have battery voltage on both small terminals on the coil when the ignition switch is in the on position. Check that with a volt meter or test lite. You should pull of your plug wire's off and see if you have fire to the plug when someone makes an attempt to start the tractor with the switch on, if you do have fire to the plug you probably have a fuel problem with dirt or rust blocking the fuel. Hal
