Re: Farmall A Final Drive Level Check Plug??
Posted by Larry Ed on March 25, 2008 at 16:31:11 from (67.142.130.18):
In Reply to: Re: Farmall A Final Drive Level Check Plug?? posted by ScottyHOMEy on March 25, 2008 at 15:43:46:
It is a NC thread, I can see that. I don't have an OEM drawbar on it, but it sure looks like it is in the right place to be a bolt for the drawbar.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
