Re: 460 engine overhaul question
Posted by Rifler on March 31, 2008 at 20:04:22 from (216.51.182.229):
In Reply to: Re: 460 engine overhaul question posted by El Toro on March 31, 2008 at 19:34:52:
Valve clearance was checked and set at 0.025" and the ring clearance was also checked before the pistons were installed. I believe the piston clearance they bored the sleeves to was 0.004".
I understand the motor (any motor) won't run on 40 psi, but I thought that might help in giving a direction to look at because I am a little baffled with the situation.
