Re: pics of my new old I806D and questions
Posted by formerly ny bill on May 16, 2008 at 02:41:11 from (66.24.240.172):
In Reply to: pics of my new old I806D and questions posted by ironandsteel on May 15, 2008 at 18:34:17:
the 806 has a 12 volt system, originally 2 6volts in series. you can use your 2 12s in parallel, since you already have them. my jd4010 has a 24 volt system and it can be a pita. sell the jd parts and get a 12 volt delco 10SI alternator. wiring diagrams are on this site in the archives. if the steering arms are already welded, the steering slop can't be coming from them. most likely, its in the tie rod ends and maybe where the pitman arm bolts on. the park lock pawl can be accessed under the top cover. does the tractor have a rhythmic clunk in the transmission when backing up? if so, the thing was put in park while it was still in gear. a coomon ocurrence with worn 06 shifting. the park pawl locks into the reverse gear when the lever is down. make sure its in neutral and take your foot off the clutch BEFORE you drop the park lock handle. the front axle still has me baffled. i still think the rear section is from a farmall, in which case the fenders are right.
