IH3588 2+2 No fuel out of injectors after sitting, clogged?
Posted by Qboneus on June 14, 2008 at 20:39:47 from (72.175.1.182):
Tractor sat for 6-7 years, ran when before stored in shed.
I need to get her going again but after fueling, replacing both fuel filters and the primary rubber fuel hose I cannot get any flow from injectors.
0 smoke while cranking, doesn't even try to catch.
I think the pump itself is fine, as If I open the fuel filter bleed valve I will get a steady stream when I crank the engine over.
when i crack the injector rails I see a steady drip out of the tubing, but I'm not sure how much I SHOULD have.
Next step was to inspect the injectors, some were REALLY stuck in there I had to rock them with a 38 open end wrench to get to loosen and eventually release from the manifold,some were easy some were really hard.
The small fuel line return on the back of the injectors was packed with fuel squirting everywhere when I pulled the hose off back of the injectors but I never saw ANYTHING emitted from the injectors orifice.
I THINK I got a hoses, ect bled off OK.
Are these injectors servicable?
One of the six came apart into two parts when I was trying to remove it and the washerssprings ( got them all) came out of sequence and I donot know how to properly re-assemble it without disecting one of the other five.
If I was to try to clean them what would you recomend I soak the injectors In?
or will this even work?
If they are beond repair is there a source for replacements and are they exoribtant?
Is there something else I should be trying?
I have lots of Gasoline experienc but this is my first deisel wrenching so any hints or tips are welcome.
Thanks for your time and consideration,
Tal
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
