Re: carb settings
Posted by ScottyHOMEy on November 10, 2008 at 13:44:29 from (70.105.230.210):
In Reply to: Re: carb settings posted by Josh Watson on November 10, 2008 at 12:44:57:
Take a look at the front end of the rod that runs from your speed control lever (the one back at the seat) where it connects to the governor. There should be two springs at the front end, one on either side of the connection to the governor. Are they both there?
