Re: carb settings
Posted by Josh Watson on November 10, 2008 at 14:09:43 from (69.131.74.150):
In Reply to: Re: carb settings posted by ScottyHOMEy on November 10, 2008 at 13:44:29:
Just one spring. The speed change lever is connected to the rod by a square steel piece about 3/4 thick which has a small pin and a cotter pin. The spring rides on the rod forward of the square piece then a washer then a cotter pin. I looked at my manual and it shows the gov. breakdown but not the linkage.
