SLipping TA on SMTA
Posted by GordoSD on November 22, 2008 at 16:26:24 from (66.115.200.140):
OK, back to this TA that is slipping on the low side.. Looking at the TA from the top, with the inspection plate removed I see that the plate is off the friction disc only about .050 with the lever back. Is this enough? It does disconnect the friction disc but should it travel further backward to fully engage the low side?
On adjusting I am at the very end (short as possible)of the threads with the clevis on the rod to the TA shaft.
Gordo
