I will take some pictures of the "junction block"-
There is a 4 terminal block in front of the fuel filter (glass globe). It has one heavy gauge wire coming to it from the + battery terminal, then another going into the starter. It also has two thin gauge (16ga or so) wires coming off of it. The first one (closest to the battery terminal side) goes to the "PUSH STOP/PULL RUN" button. There are about 5-6 wires that branch out off of that button. Two of these wires have in-line fuses and another has a flasher. I checked the fuses and they are good. I believe they power the rear spotlight and the fender mounted yellow flashers. The difficult thing is all the wires are bound together very tightly and I need to get some replacement zip ties before I want to start cutting them all out. That and the wire colors are all red and black, and are not used correctly (red is not all + and black is not all ground - for example one of my in-line fuses has a red wire going into one side and a black wire coming out the other. This wire is hot when the ON button is out and should be +).
I will clean all contacts as I thought I should be getting 12V (or high 11V at least!) at all contacts. I believe my junction block is a relay for the starter. I just can't figure out where the disconnect is, although I have a feeling it is the push button starter. I was just wondering if anyone knows how to go about testing it?
Where do I find a replacement or can I repair this one? Thanks for the help so far!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
