Rear mounted Mower on an Farmall A
Posted by TWheat on November 30, 2008 at 12:12:24 from (76.3.172.45):
I don't know the mower model #,but it is rear mounted, has a manual lever for the bar, has a belt drive from the pto driven top pulley to the lower pitman pulley.I need to replace the pitman shaft,pulley and arm(all on piece).That part # is M 2572. How does the shaft come out? and What holds it in? . I took the front plate off(4 bolts)which reveals the shaft turning in a bearing, but no clue how to get it to come out.
Thanks
