In that case, start with your valves. Just for giggles, just do an eyeball check of your ignition rotor relative to the position of your pistons. It would be durned unusual, too, even if the head were left to rust full of rainwater, for the valves to have stuck with one open on every cylinder. I'm startin' to suspect somethin' along the lines of a bad cam gear/valve timing. Can't rule out somebody in the past havin' a pull-the-tractor-pop-the-clutch party to get a stuck motor free, either. That can bust rings in a hurry.
Get your valve cover off and watch while it cranks and see what you've got there.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
