IH 364 Stops running
Posted by flyerjeff on February 15, 2010 at 05:36:13 from (98.24.60.195):
I have an I/H 364 Diesel. After it warms up (approx. 30 mins), when placed under a load it will loose its prime and cut off. I have tried all the mechanical fuel pump tricks and even installed an electrical pump. Mechanic says its most likely a bad injector pump. Rebuild and installation is just under $1000. What are your thoughts and is it worth it? Otherwise I have a large piece of metal. I do, however, really like the tractor.
Thanks,
Jeff
