Re: No oil pressure.
Posted by CNKS on February 12, 2011 at 06:30:33 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by Tom Fleming on February 12, 2011 at 05:34:15:
Certainly possible, but where? Gene Bender says there are none in front, if in the rear or anywhere else external it would leave a puddle. I don't remember any internal ones, if they exist I suppose I could have missed one. Engine was apart for a year while I slowly did the rest of the tractor. I do remember running a brush through them, and blowing with compressed air to see where the air exited.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
