560 Hydraulics cant hold implement up
Posted by heyiou on March 21, 2011 at 12:01:41 from (69.29.44.91):
I have a 560 LP with a 3 point and it will lift an implement but it loses pressure. For instance, with a brush hog I have to constantly bring the 3pt back up and it starts dropping immediately. 20 secs later have to raise it again it keep the blades off the ground, etc.
Also, will the stock pump run a farmhand f11 or do you have to have a pto pump? Thanks for any help.
