Re: Super M hydraulics problems
Posted by Janicholson on September 30, 2011 at 16:27:27 from (96.24.99.126):
In Reply to: Super M hydraulics problems posted by JTBARTLETT on September 30, 2011 at 15:49:42:
If the Valves are not open center (free to return all pump output to the reservoir when the valves are in the neutral position, it will cause that effect.
The system is continuously bypassing due to the closed center valves. (just a guess) The loader cylinders are leaking fluid past the piston seals (I bet it would slowly go down if left up in the air. As oil fills the place where there should be air, it comes out past the wipers. Pictures would help us be sure we are giving you good info. Jim
