Re: Re: Re: IH tractor plug fouling problem
Posted by ltf in nc on September 20, 2000 at 09:34:33 from (206.228.214.82):
In Reply to: Re: Re: IH tractor plug fouling problem posted by Gene on September 20, 2000 at 09:21:22:
Black exhaust, no oil consumption and soot appearance on the plugs indicate only one thing to me. Too much gas to air ratio. Can you substitute the carb? Also, thoroughly check the inlet air. Too little air is the same as this will create the wrong ratio. Have you tried to operate the engine at the shop with the air inlet disconnected to see if the black smoke stops?
Post A Followup
: Re: Re: Re: Re: IH tractor plug fouling problem
