An opinion. The linkage from the throttle hand lever moves rod/s to the governor housing. If these move as they should, the connection of the lever to the shaft going inside could be broken. Inside there are nuts and washers holding a spring lever to the shaft. That lever could be worn and slipping on the shaft. If the weights are pivoting on their pins, but not loose, and the Governor rock shaft is free to slide, it should work. One of these is either jammed or worn. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
