Re: Re: Marvel Schebler Carburetor for IH tractor
Posted by Gene on November 10, 2000 at 14:49:10 from (205.188.192.53):
In Reply to: Re: Marvel Schebler Carburetor for IH tractor posted by Rich Cota on November 10, 2000 at 12:08:34:
Rich, I have run out of ideas of what to try to do with the tractor. Thanks for your response. I have had suggestions from the forum before and have tried, I think, all of them. I have had the carburetor overhauled twice, checked the float level, the air intake, replace the air filter, changed to a higher octane fuel, changed to hotter spark plugs (D21 Champions), replaced the ignition coil, the points, condenser, distributor cap and rotor and the primary wire to the coil from the distributor. Still the same old thing. It runs fine after the plugs are cleaned or replaced only to foul out again after a few hours of operation (not hard use, but short term use several days in a row). I have noticed one thing about the carburetor is that a slight amount of gasoline drip forms on the bottom of the carb after it has sat for several hours. It is not enough to drip, but it weeps and evaporates. After you start it and run it for several minutes, that dries up and there is no weeping again until after the engine is off for several hours. This has been going on for years, I have had it to a repair shop for mechanics to look at it, and they have not solved the problem, saying that everything seems to check out. But, it is really frustrating to get ready to do some heavy duty field work and you have to make a pit stop to clean the spark plugs before it will run. Sometimes when the plugs are fouled bad enough it barely can be brought home to the garage to work on it. Thought I would swap the carburetor and see if that is the culprit. Thanks for your help!
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
