Re: 1945 Farmall M Vapor Lock
Posted by Janicholson on February 15, 2014 at 16:20:37 from (74.60.94.18):
In Reply to: 1945 Farmall M Vapor Lock posted by blohr on February 15, 2014 at 15:02:09:
M Farmalls have a gravity feed fuel system. Italso has staal fuel lines that are not close to hot engine components or exhaust. As Rustred points out, the only way to get vapor lock is to have a plugged up vent in the fuel cap. (this would cause the fuel to fail to be delivered to the carb.
Tell us more about your symptoms. (also if you have a fuel filter other than the sediment bowel and the screen at the carb, remove it, they are (usually) not designed to operate with only gravity power. Jim
