Re: starter motor will not stop running
Posted by old on August 29, 2014 at 13:47:30 from (209.86.226.59):
In Reply to: Re: starter motor will not stop running posted by homebre973 on August 29, 2014 at 13:43:02:
6 volt solenoids and starter will work just fine on 12 volts but a 12 volt solenoid or starter will not work on 6 volts. As long as the 12 volt one is wired the same as in the same number of posts you can go with either one your call
