Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Red Dave on May 27, 2001 at 15:49:28 from (64.41.22.149):
In Reply to: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Gene on May 27, 2001 at 14:41:10:
Gene, just out of curiosity, if it were mine I would put a jumper (14 guage wire or larger) from the switch to the hot side of the coil and see how it runs. This would effectively eliminate the 2 ohm resistance temporarily and give you a glimpse of what it would run like with a 6 volt coil. It doesn't have to be a fancy wiring job, don't remove anything, Aligator clips to the terminals is sufficient to try it. A 12 volt coil is just a 6 volt one that has the resistor built in. I agree that you need an internal or external resistance, but not both.
Post A Followup
: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
