Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Gene on May 27, 2001 at 14:41:10 from (205.188.195.56):
In Reply to: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Bob M on May 27, 2001 at 14:17:34:
Bob M:
Thanks for the quick response. You mentioned using a 6 volt coil. Even though this is a 12 volt system ? I know nothing about coils, as you can see. Thanks.
Post A Followup
: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
