1941 M going dead
Posted by Jeff Pirkey on August 15, 2001 at 15:40:22 from (63.31.179.41):
My M is still having problems. It was dieing out as if starved for gas under a load. I just completed rebuilding the carb including a new float. I also installed an inline fuel filter and a new gasket in the site bowl. After starting the engine and adjusting the carb I was able to bush hog for about 10 min. before it started dieing out again, requiring me to pull the choke to get out of the field. I then pulled the cover off the govenor and found nothing that seemed out of the ordinary. But then again, this was the first time I've looked at a govenor on a tractor so I probably wouldn't know ordinary if it bit me. However the spring wasn't broken. Any Ideas as to what to check next?
Post A Followup
: Re: 1941 M going dead
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
