Farmall Tractors Discussion Board
Re: 3 good tune-up tips for beginners, back to back (#1)
Posted by mj delaney on May 31, 1999 at 07:11:49 from (198.167.60.43):
In Reply to: 3 good tune-up tips for beginners, back to back (#1) posted by RKS on May 31, 1999 at 05:06:50:
This is all good advice.
I like to do things as simple as I can. To set the camlobe at tdc. I just push on the fanbelt and bring the engine up to tdc with the fan blade. I find tdc by shoving a small screw driver down the spark #1 plug hole. If you are too rough with the fan blade, this is not a recommended method. If you are gentle, it works not too bad.I've owned my H for twenty years now with no ill effects using this method. As far as timing is concerned, my H has always started as long as the points are set anywhere close. I don't have a dwell meter or timing light. If you have too much advance, the engine doesn't crank too well, not enough and it seems the motor is lazy. There's quite a variation in idle quality when you shift the timing. You just know when you've got it right especially if you have a good load for the tractor. Properly tuned, the "H" will lug right down to a heart beat although this is not recommended. The "H" is built to work and for a small gas tractor, they really are good performers.
I can pull a baler and wagon loaded with 200 bales just about any where in low gear. This will haul the rpm's down especially on a grade!
Post a Followup
: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
