Bob M.( Crankshaft to Camshaft Timing )
Posted by Slick on January 29, 2002 at 14:10:04 from (64.154.157.104):
Thanks for the lead. Took the hydraulic pump off of tractor, reached into the timing cover and found that (like you said) the timing gear was loose. Looks like the front of the gear is chewed up. Do you think that this is caused by a problem with the hydraulic pump? You can add a 300U to your list!
Post A Followup
: Re: Bob M.( Crankshaft to Camshaft Timing )
