Timing an H
Posted by Dick Davis on February 02, 2002 at 15:51:28 from (152.163.197.83):
Cannot find the index marks on cam and crank gears! (Should have done a better job of marking!) If number one cylinder is at TDC, both lifters for # 1 and both lifters for #4 cylinders should be at lowest position. Is that correct? Seems like I recently read this but can't find it tonight. Appreciate any help. Dick
Post A Followup
: Re: Timing an H
