Farmall Tractors Discussion Board
Need help!
Posted by Pastor Don on August 30, 1999 at 11:58:32 from (207.12.176.223):
Just took delivery of a Farmall 300, it came off of the truck with a plow in the raised position. I cannot get the Hydra-touch to lower the implement. It won't go up and won't go down. Hence the plow is binding and I can't remove it. Can I do the following? Jack up the plow (car jack) release the pressure by the pressure release valve ???? and then lower the implement slowly with the car jack. Then close the release vavle and try the hydra-touch again? Any other ideas if this isn't correct? Novice to say the least and a bit scared since the front end already came up two feet just trying to pull this off. Pastor Don
Post a Followup
: Re: Need help!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
