Farmall Tractors Discussion Board
Re: Can an IH 6v generator be converted to output 12v?
Posted by ltf in nc on October 15, 1999 at 11:34:49 from (206.228.213.35):
In Reply to: Can an IH 6v generator be converted to output 12v? posted by JR on October 15, 1999 at 09:25:08:
Your 6 volt system has a cutout instead of a regulator which is used to isolate the battery when the engine is turned off to keep from discharging the battery. I would not want to run this system with a 12 volt generator because if you use the tractor very much the higher output 12 generator will overcharge the battery. To install a regulator with the converted generator would require a wiring change that is somewhat involved. If this is a working tractor I would not hesitate to go to a 12 volt alternator w/ a built in regulator system. The existing wiring can be used with only a minimal modification. It would be cheaper and the parts are readily available. The most difficult part of the conversion is mounting the alternator and if you will go to the junk yard and get a couple old car brackets they can be modified to accomplish this task. Truly good 6 volt batteries are hard to come by and the price continues to rise. And finally, as you have found out, the tractor will crank a heck of a lot easier. I can not understand why the reluctance exists in converting a working tractor.
Post a Followup
: Re: Re: Can an IH 6v generator be converted to output 12v?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
