Farmall Tractors Discussion Board
Can an IH 6v generator be converted to output 12v?
Posted by JR on October 15, 1999 at 09:25:08 from (208.216.106.99):
I have a 1947 IH I-4 tractor with a working 6v generator. However, the engine will seldom start when on a (new) 6v battery. A 12v battery works great. I would like to keep the positve ground system and convert the generator to output a high enough voltage to charge a 12v battery. Is is possible to do so? The generator is a Delco-Remy with the "voltage regulator" mounted on top of it. The "voltage regulator" only has a single relay. Is that only used to connect the generator to the battery when running and disconnect when not running? The generator and wiring match the parts shown in a parts manual for the system without lights. Help!
Post a Followup
: Re: Can an IH 6v generator be converted to output 12v?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
