Re: Farmall 100 (?) Serial Number Question
Posted by Hugh MacKay on June 21, 2004 at 15:58:32 from (64.228.11.68):
In Reply to: Farmall 100 (?) Serial Number Question posted by Ramon on June 21, 2004 at 13:20:33:
Ramon: The 1666 J is your serial number and 1575 is your max engine rpm. To determine whether it is 100 or 130 go to the casting codes Z is 1954, A is 1955, B 1956, C is 1957. A 100 could also especially being first year have a few 1953 castings being Y.
I'm kind of curious about your engine block part number, just behind oil filter, cast letters about 3/4" high and ending in R1 or R2. Also just under number one spark plug, and behind throttle linkage is a flat machined surface. Engine serial number will be stamped on that flat surface, could be 2 lines. Let me know these numbers. Thankyou.
Post a Followup
: Re: Re: Farmall 100 (?) Serial Number Question
