Re: cuts out....gas?
Posted by ToddH on May 28, 2005 at 09:55:31 from (64.78.123.117):
In Reply to: Re: cuts out....gas? posted by riverbend on May 28, 2005 at 09:05:28:
I"m not sure where the plug is. Should I disconnect the fuel line where it connects to the carb to check for flow?
Post a Followup
