424 International
Posted by Rick Bright on September 19, 2006 at 08:49:17 from (166.102.153.56):
I tried to do a search for information before I posted questions on this tractor, cannot get the search feature to work so here goes. I am needing a tractor to pull a 5' rotary cutter mostly clipping 20 acres of pasture, found a IH 424 diesel, bad faded paint very straight sheetmetal, has some blow-by , had to crank on it for about 15 seconds quite a bit of white/grey smoke when cranking before it started. After it warmed up a little dark smoke and still some blow-by. Owner said it does not have power steering, steering wheel says it does if so it does not work. Are parts available for this? He is asking $1900 I think he might drop a couple of hundred. Any thoughts or comments on the 424 appreciated.
Thanks,
Rick
