Super-A ?...esp. Scotty or Banjo
Posted by Pa. Pete on October 19, 2006 at 16:23:33 from (207.7.183.166):
third party image
F/U to my "Super A Mystery" post-
You gentlemen saw the picture of the lost-washer-in-the-pan from my other post. I believe it is an axle-washer that had been dropped in the pan and never retrieved.
My parts-book shows TWO washers, which 'sandwich' the inner bearing, however they have different part-numbers, and I assume are thus different. So I cannot tell which washer is the one I found.
