Re: Super-A ?...esp. Scotty or Banjo
Posted by Pa. Pete on October 19, 2006 at 16:27:41 from (207.7.183.166):
In Reply to: Super-A ?...esp. Scotty or Banjo posted by Pa. Pete on October 19, 2006 at 16:23:33:
Here is a picture of what's under the inner cover of that right axle. I can see a washer against the bearing that has the same outer diameter as the lost washer. I don't know if there is a washer on the other side of the bearing. So it may or may not be properly re-assembled. As the axle must be "driven out", and as I have been driving it without problem, I'm not going to disassemble now. The answer I need now: My 'parts' book doesn't show the BOLT. I expected a castellated nut with a cotter pin, to adjust the bearing/axle looseness. Instead, I find a 'bolt'-head. Thus, I'm now assuming that the bearing adjustment must be done with that 'lugged'-spacer, and then the bolt torqued down. Is this correct? I don't want to put any stress on the bearing from over-tightening, but I don't want to leave the bolt loose either, if it's supposed to be tight. And since that bolt is currently un-torqued, should I remove that tire to have a better 'feel' for the bearing adjustment? Appreciate your time.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
