Micheal, Since its an A which should be well able to crank over n start at the original 6 volts (use 00 Gauge battery n starter n ground cables n a bigggggggg heavy rated battery) Id leave it at 6 volts.
I agree with ny friends below, YOU NEED TO FIRST CONVERT FROM THE MAGNETO TO A REGULAR COIL DISTRIBUTOR IGNITION AND THENNNNNNNNN CONVERT IT TO THE ELEC IGNITION. Once done then YES the elec switch unit fits easily right in place to replace the points n condensor. Then to get the most bang for the buck and to utilize the benefits the elec switch has to offer I highly recommend you use a high performance 6 volt coil (if they ofer one, otherwise use the stock 6 volt coil) as specified by the elec switch vendor that matches up with yur new elec switch.
MAKE SURE N BUY THE ELEC SWITCH FOR 6 VOLTS AND ESPECIALLYYYYYYYYYYYYYYY TO MATCH YOUR TRACTORS GROUND (Pos or Neg) and then buy a high performance 6 volt coil to match the switch if they offer one (or the stock 6 volt coil will still work)
Get a good working distributor,,,,,,replace points n condensor with the new 6 volt CORRECT GROUND elec switch unit,,,,,,,,mount the new high performance or regular 6 volt coil,,,,,,,,wire it at the CORECT POLARITY (if Pos ground + wires to dist if Neg ground - wires to distributor) ,,,,,,,,,,,,you will need an On/Off Ignition Switch of course installed near the dash (post back if you need help on that)
You may wanna check with Pertronix Ignition to see if they offer a 6 volt elec switch and if so at Pos or Neg ground??? then if they offer their own matching coil. AGAIN BE SURE N GET TEH RIGHT VOLTAGE SWITCH AND THE CORRECT GROUND. If they only offer Neg ground and youre at Pos ground you will have to convert over !!!!!!!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
