Re: Farmall A Final Drive Level Check Plug??
Posted by ScottyHOMEy on March 25, 2008 at 15:43:46 from (71.241.213.254):
In Reply to: Farmall A Final Drive Level Check Plug?? posted by Larry Ed on March 25, 2008 at 15:28:13:
Can't think of another plug other than the 1" pipe plug that is the fill hole.
Is the drawbar on the tractor? If not, I suppose it could be one of the holes for mounting the drawbar, but I thought those were blind holes.
If it is one of the holes for mounting the drawbar, it'll take either a 1/2" NC or a 5/8" NF, depending which hole it is.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
