Posted by Janicholson on December 13, 2008 at 19:04:23 from (64.83.205.193):
In Reply to: Re: 460 gear clash posted by CNKS on December 13, 2008 at 18:31:23:
CNKS, I think lost motion is your problem. The clevices and pins as well as shaft clearance in the housing all ad to the total slack. The free play setting shaoul withdraw the T/O bearing fully off of the fingers. If it does not, some lost motion is happening. A worn pin, a ovaled out pivot, or other loose fitting. Both clutches should be very free when fully disengaged. When in TA, the TA clutch must be free to float. Put it in gear, TA back. Hold the clutch down, Take it out of gear. If the trans spools up and crunches when a gear is selected, the TA clutch is dragging. If it does it in Direct the same way, The master clutch is dragging, or the pilot bearing is tight or gummed up driving the input shaft. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
