Posted by ScottyHOMEy on August 18, 2009 at 11:49:50 from (70.105.246.162):
In Reply to: 140 no compression posted by Brad M-C on August 18, 2009 at 11:38:49:
Fill???? It shouldn't take more than a tablespoon or so per culinderImproved compression with oil on top of the pistons indicates worn rings. The oil provides a temporary seal. Still rings in a 123 that would produce 150# with a little oil on top should be showing you some compression dry.
You may also have valve issues if the engine is that badly worn, but the fact that you were able to build 150# I wouldn't expect a serious valve problem.
Just from your description, I'm a little worried about your test method. How much oil did you actually put into each cylinder?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
