farmall h governor
Posted by jim from az on March 01, 2010 at 18:29:43 from (67.40.93.102):
i had valves ground in head and put it back together i put governot shaft into slot in carb , but it idles but, when i advance the throttle lever it won;t back down unless i shut off ignition .. i can't figure it out any help will be appreciated.. thanks jim
